How can I configure PHY 8720A in CubeMX?
In the Advanced Parameters of the ETH configuration, there is only the LAN8742A external PHY configuration. Is it possible to use an other external PHY (like 8720A) using CubeMX?
I tried with the user PHY, but I don't know where I can find the configs for the PHY 8720A. I tried the datasheet, but there's nothing like Read TimeOut or Write TimeOut.
Did anyone already created a project with PHY 8720A on CubeMx and can tell me about the configs or where I can find them?
Thank you very much.
#ethernet-stm32f7 #cubemx-4.25 #phy-8720a #external-phy #ethernet-phy
