IReta.1
Aug 23, 2021 7:05 PM UTC
Hi all, I am at my led blinking test and works fine. I want to use more GPIOs in it. I do not want to make a new project, I want improve the actual one instead. How can I get back to the initial graphic Cube environment to add new pins? Steve
TDKBest answer
Aug 23, 2021 7:37 PM UTC
If you created the project, the IOC file should still be present in the Project Explorer window in STM32CubeIDE. Double click it to open.
Aug 23, 2021 7:33 PM UTC
You can't convert code to an IOC file (used by CubeMX), if that's what you're asking. You can only go from IOC to code.
TDKBest answer
IReta.1
IReta.1Author
Aug 24, 2021 4:32 PM UTC
A big THANK YOU ! :grinning_face:
