Hellp start to CubeMX
Hello friends, I am starting to use "CubeMX", I want to configure memory, static RAM and LCD. But I'm having trouble figuring out how to configure these peripherals, do you have a guide to configure this peripheral and CubeMX?
Thanks!
KDJEM.1
KDJEM.1Best answer
Hello @A.Rade.96 ,
I recommend you to follow the steps shared in AN4861 "LCD-TFT display controller (LTDC) on STM32 MCUs" and precisely "LTDC application examples" Section.
This section provides an example based on the STM32F746G-DISCO board, describing the steps required to create a basic graphic application by using STM32CubeMX.
 I hope this help you!
Kaouthar
KDJEM.1
KDJEM.1Best answer
Hello @A.Rade.96 ,
Kaouthar
A.Rade.96Author
Thanks to answer, but, my problem is configuration NE2 and NE3 occur is problem to conflict. Also, problem is to configuration Bank, I'm configuration Bank1 but, cubemx be generated to code bank 3. What is the problme ?
KDJEM.1
Hello @A.Rade.96 ,
  • Could you please precise the STM32 product you are using?
  • Which STM32CubeMX version are you using?
Thank you.
Kaouthar
