RNoot.1
October 12, 2020
Hello, I am facing an issue with CubeMX to keil Code generation failing ,Please Help me to resolve my issue? Thanks.
Hello @RNoot.1​ ,
Please provide more details on your issue: which CubeMx, Java and keil version used ?
Note that the max JAVA version supported is actually JAVA 11, this is mentioned in the UM1718: Java 11 is supported. Java 7, Java 9, Java 10, Java 12 and upper are not supported. So, please switch to another java version if you are using JAVA 13 ?
Otherwise, this issue could be caused by installing MDK-ARM. So, try to uninstall then reinstall MDK-ARM.
Please keep me informed about your progress on this issue.
If it is not resolved, please share your ioc file, then I will raise your issue internally to CubeMx team.
Imen
Hi @RNoot.1​ ,
Do you have still this problem to solve?
You can attach the ioc and log file that help us to reproduce your case.
Please keep us updated.
Imen
