NSmir.1
Apr 17, 2020 10:26 AM UTC
Hello, everyone!!! Unfortunately, I can't configure the center-aligned PWM mode. Someone can show you in detail how to do this in CubeMX. Thank you very much!
Houssem CHAABANI
Houssem CHAABANIBest answer
Nov 17, 2020 10:15 AM UTC
Dear @NSmir.1​
You need to activate a timer under timers and configure channel1 as a PWM generation channel.
In the timer configuration you should select the Counter mode to Center aligned mode 1.
Then you can go back to the GPIO configuration and choose the mode to TIM1_CH1.
Hope that this help you,
Kind regards,
Houssem
Houssem CHAABANI
Dear @NSmir.1​
Kind regards,
Houssem
