Generated CMake projects use deprecated CMakeForceCompiler
I've noticed that the generated CMake projects (specifically, in the toolchain gcc-arm-none-eabi.cmake file), a now-deprecated (since version 3.6!) macro is used https://cmake.org/cmake/help/latest/module/CMakeForceCompiler.html
I have to remove/comment out the use of these macros in my code due to it causing issues with other CMake libraries that I use in my project, which somewhat defeats the purpose of the CubeMX generated code to begin with.
Hopefully this is seen by the right person and this issue is addressed.
Thanks!
Souhaib MAZHOUDBest answer
Hello @drewhanshaw
Thank you for bringing this issue to our attention,
 Issue escalated internally (Internal ticket number 191267). I will get back to you for any feedback.
KR,
Souhaib
To give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question.
Hello @drewhanshaw
KR,
Souhaib
Do you have an update on this ticket?
