DiBosco
Senior
FreeRTOS configCHECK_FOR_STACK_OVERFLOW set to 1 but vApplicationStackOverflowHook greyed out
Folks,
I have FreeRTOS running on an H563, trust zone not used. Created the basic setup from an ioc. I have an ocassional task starvation issue and want to double check there's no stack overflow (unlikely but must check).
If I set configCHECK_FOR_STACK_OVERFLOW to 1  in FreeRTOS.h
In cmsis_os2.c, vApplicationStackOverflowHook is still greyed out and hovering over configCHECK_FOR_STACK_OVERFLOW claims it's set to 0. control clicking on it takes me to the defintion where it is set to 1.
Anyone know what is going on here please? And why is it set in FreeRTOS.h, not FreeRTOSConfig.h?
unsigned_char_array
Lead III
In STM32CubeIDE: Project->C/C++ Index->rebuild
"Kudo posts if you have the same problem and kudo replies if the solution works.Click ""Accept as Solution"" if a reply solved your problem. If no solution was posted please answer with your own."
unsigned_char_array
Lead III
Did you build? Have you tried rebuilding the index?
DiBosco
DiBoscoAuthor
Senior
Yep, naturally I built it. I don't know what you mean by rebuilding the index though, sorry.
unsigned_char_array
Lead III
