Flash memory - STM32F030C8 Erase Cycles
Hello
I'm using STM32F030C8.
I'm writing the code because I want to use the internal flash memory like rom.
Is there a set number of times I can write in internal flash memory?
If there is a related document, I would like to see it.
Thank you.
Tesla DeLoreanBest answer
July 25, 2024
https://www.st.com/resource/en/datasheet/stm32f030c8.pdf
Endurance 1000 cycles
July 25, 2024
giwonKIMAuthor
1 cycle means 1 time write?
July 25, 2024
You can journal across all the flash words in a page, you may write each flash word once.
You must erase page before changing content, you can erase each page >= 1000 times
giwonKIMAuthor
Thank you.
Now I understand about that.
I am always grateful for your response.
