Dejan Nedeljkovic
Sep 4, 2020 6:06 AM UTC
FatFs in LFN Mode: I get always FR_NOT_ENOUGH_CORE on f_open()
Hi
I've configured FatFs for SD 4Bit Bus and using FreeRTOS. I've set USE_LFN = 3 (dynamic working buffer on the HEAP)
When I call f_open() it always returns FR_NOT_ENOUGH_CORE.
The SD card calls are made in a seperate Task.
When USE_LFN = 0 then all works well.
Did I forget to set something?
Dejan
Sep 4, 2020 6:37 AM UTC
Check heap size, especially Keil.
Still failing, track malloc() usage.​
Dejan Nedeljkovic
Sep 4, 2020 7:15 AM UTC
Hi @Community member​
Heap size looks ok. I have 22 kBytes left.
Dejan
Sep 4, 2020 7:19 AM UTC
Probably want the breakpoint code if ff.c throwing the error, or instrument malloc/free calls.​
