oeliks
Dec 24, 2019 9:48 AM UTC
Exclude files from update in cubemx
Hi! I changed usb hid.c file not in user code. After I change something in cubemx and regenerate code this file is also changed to its oryginal form.
Is there a way to tell cubemx not to change this specyfic file?​
dbgarasiya
dbgarasiyaBest answer
Senior
Dec 28, 2019 10:48 AM UTC
according to my knowledge when you regenerate code all files will ramains as first as it is
dbgarasiya
Senior
oeliks
oeliksAuthor
Dec 28, 2019 11:32 AM UTC
Thanks, well I will change it manually then.​
dbgarasiya
Senior
Jan 1, 2020 10:44 AM UTC
Best of luck @oeliks​
