Ethernet and USB Pin Conflict Warning on STM32F407ZGT6 in STM32CubeIDE Software Tool
- 0 replies
- 456 views
I am working with the STM32F407ZGT6 microcontroller and have encountered a warning related to Ethernet and USB functionalities being assigned to the same pins.
While I have attempted to resolve this by using alternative pin mappings, the conflict warning still persists.
I would like to clarify the following:
Understanding the Warning – Despite assigning Ethernet and USB to different available pins, the warning remains. Could you provide insights into why this occurs and whether it impacts functionality?
Resolution Approach – Are there specific configurations, software settings, or modifications required to eliminate this conflict?
Technical References – If there are any relevant technical documents or application notes addressing this issue, I would appreciate your guidance.
Any insights or suggestions would be greatly appreciated!
Thanks in advance!
Best regards,
Ishika Sapkal
