Adrian Adamson
Senior
March 5, 2019
Error setting up dual bank quad SPI
When I try to set up quad SPI with dual bank on an STM32H7, I get the following message:
"You must select a ChipSelect signal for Dual bank mode first"
This is true even for a blank project with nothing else assigned. I don't see anywhere available to select the chip select lines.
Khouloud ZEMMELI
Khouloud ZEMMELIBest answer
​Hello @Adrian Adamson​
Thanks for the feedback.
You are right, This issue will be fixed in the next CubeMX release.
Best Regards,
Khouloud.
Khouloud ZEMMELI
Best Regards,
Khouloud.
Adrian Adamson
Senior
March 6, 2019
Thank you for your help. Hopefully the update will be soon. I'm working on the board layout now and I do need to know which pins to route to for those chip selects. I guess for now I should assume that they are the same pins used for NSS in the other QSPI modes?
March 6, 2019
Will PM you schematic section I've worked from.
