Does STM32C071CBT6 support PLL for external oscillator?
I am using an 8 MHz external oscillator and was planning to use a PLL to increase the system frequency. However, when I open the Clock Configuration tab in CubeMX, I don’t see any option for a PLL.
I’ve also shared a screenshot of the clock configuration where it’s clear that the PLL option is not available.
So my question is: Does the STM32C071CBT6 microcontroller support PLL with an external oscillator?
Andrew Neil
Andrew NeilBest answer
What makes you think the STM32C071CBT6 has a PLL?
There is no mention in the Datasheet
That would explain why CubeMX doesn't show it
Andrew Neil
Andrew Neil
however, there are three mentions in the Reference Manual:
https://www.st.com/resource/en/reference_manual/rm0490-stm32c0-series-advanced-armbased-32bit-mcus-stmicroelectronics.pdf
via: https://www.st.com/en/microcontrollers-microprocessors/stm32c071cb.html#documentation
@STTwo-32 These look like copy-paste errors in the RM ?
STTwo-32
Hello @Andrew Neil
I've escalated this to the doc team for review (under internal ticket number 212567).
Best Regards.
STTwo-32
