BSerb
Disable auto comment generation
I understand the reason behind it and it is a very useful feature, but please add the option to disable it when it's not needed. Most of the time I just do a one-off configuration using the cube configurator and then I write my own code. Also, the way the comment blocks are written makes everything very tiring to follow, so maybe it could be useful to be able to define different styles of comments.
ChahinezC
Hello @BSerb​,
Thanks for your contribution and your suggestion.
Currently, we have a dedicated area for Customers' ideas; the Idea Zone. You can add your proposal there, and if relevant for them, other Community members can vote for it. Then, our Experts will be able to review it.
Chahinez.
You could consider writing a utility to strip out the comments from the generated code.
