CubeMX v6.12 generate wrong makefile project
I use CubeMX + VSCode + arm-gcc + makefile to compile embedded programs. CubeMX v6.12 create wrong stm32fxxx_flash.ld file. Some words like "RAM" is lacked. And CubeMX v6.11 and CubeMX v6.10 is right.
mƎALLEm
mƎALLEmBest answer
Hello @Soraka and welcome to the community,
Try the latest version 6.13 ..
mƎALLEm
mƎALLEmBest answer
SorakaAuthor
Thanks. I saw related answer in STM32CubeMX errata 6.12.x.
mƎALLEm
Did you test 6.13 and check if the behavior still there?
Andrew Neil
toroid
Explorer II
December 18, 2024
Had the same problem with a project using H7 series. I can confirm that updating CubeMX from 6.12 to 6.13 fixed the issue.
