Cfera.1
Mar 30, 2020 8:41 PM UTC
CUBEMX Using LWIP with Freertos doesn't create the MX_LWIP_Process();
I am using  LWIP with FREERTOS. I see that CUBE has put the LWIP init function in the default thread but it did does not create the MX_LWIP_Process(); that you would normally call in the always loop if useing LWIP without freertos. Is this just a bug or does this work in a different way
Piranha
Principal III
Apr 1, 2020 12:13 PM UTC
