JAlth
Oct 8, 2018 8:19 AM UTC
CubeMX - User Code sections are deleted after regeneration
I am generating the basic initialization of my projects code with CubeMX. As far as I understood it, the user can insert "USER CODE" sections to prevent the automatic code generator from overwriting these code blocks.
In my case, I want to prevent the RTC from being initialized, in case it has already been initialized before.
CubeMX generates this code (pseudo code)
RTC.Time.Hours = 0;
RTC.Time.Minutes = 0;
RTC.Time.Seconds = 0;
RTC_Set_Time(RTC);
RTC.Date.Year = 2018;
RTC.Date.Month = 10;
RTC.Date.Day = 1;
RTC_Set_Date(RTC);
I Implemented the following check:
/* USER CODE BEGIN RTC_CheckInit 0 */
 if(RTC not configured yet)
 /* USER CODE END RTC_CheckInit 0 */
RTC.Time.Hours = 0;
RTC_Set_Time(RTC);
RTC.Date.Day = 1;
RTC_Set_Date(RTC);
/* USER CODE BEGIN RTC_CheckInit 1 */
 /* USER CODE END RTC_CheckInit 1 */
But when I regenerate the code via CubeMX, my user code sections are getting deleted.
Did I get something wrong about these user code sections?
Thanks and greetings!
