Aug 27, 2025 5:23 AM UTC
CubeMX USB RTOS issue
在32位中,字的单位应该要*4吧?为什么这里直接是按字节赋值???坑死我了
Translation:
"In 32-bit, the word unit should be * 4, right? Why is it assigned directly by byte here? ? ?"
Edited by ST moderator to be inline with the community rules.
In next time please write in English as it's an international community. Thank you for your understanding.
Aug 27, 2025 9:45 AM UTC
Hello
What is the MCU part number you are using?
To give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question.
Oct 31, 2025 5:20 PM UTC
Hello @dxgvbsdfgsd
The user must be aware that the macro is defined in words. In this case you should use it as a value in words and convert it to bytes when required. For example, in definition of defaultTask in main.c the stack size is multiplied by 4to convert it from words to bytes.
BR, Souhaib
