Grisby
Feb 11, 2021 3:49 PM UTC
CubeMX SPI1 Missing CS on PD14. (Arduino-Header D10 on Nucleo-H743ZI (MB1137))
I use Nucleo-H743ZI and want use the Aduino-Header. On Board MB1137 PIN D10 (CS) is conneted to PD14. In CubeMX SPI1 NSS1 is set to PA4. I can not change to PD14, because there is no SPI1_CS in PD14 in CubeMX. How can I fix this?
I don't want change the source code after every generate.
Houssem CHAABANI
Feb 11, 2021 4:13 PM UTC
Hi @Grisby​ ,
Thank you for these details.
Could you share your .ioc file to check this issue ?
