ANauz.1
Senior
September 21, 2023
CubeMX set files in read only mode on each generation
I'm working with STM32CubeMX version 6.9.2
Each time I generate, all files in Drivers and in Middlewares\Third_Party\FreeRTOS directory are set in read only mode. I can remove it, and each time read only mode is set again.
This is really annoying!
Seen when generating for L4 µC
Ghofrane GSOURI
Hello @ANauz.1
First let me thank you for posting.
Actually I couldn't reproduce the issue, could you please provide your IOC in order to push further the investigation.
Thx
Ghofrane
ANauz.1
ANauz.1Author
Senior
September 21, 2023
Here is the ioc file I'm using. I just tried in a new empty directory, and I still get the error. Files in Drivers directory are generated (and regenerated) in read only mode.
Antoine
Pavel A.
September 21, 2023
The Process Explorer can help you understand why a certain file is read-only: is it created in this mode by Cube or something else does it later.
