Nov 17, 2020 2:25 AM UTC
cubemx project
- 4 replies
- 1087 views
I use cubeMX version6.0.0,generate a simple serial port project, I need to click three times 'run' can run to the main function(break point) use jlink in debug mode ,
The serial port tool has output character,. But direct download and re power-on does not work.
Self-made board: stm32f446ret, other projects(mbed os) can be downloaded and run directly. In debug mode, only need to press run once, there is no problem with the board
