ATirl
Sep 11, 2018 6:20 AM UTC
CubeMX PCC doesn't allow me to set clock, reason ?
Below images show a PCC step configuration window and my clock tree configuration. As seen i can not change info under clock tab of PCC. Anybody know the reason ?
Amel NASRI
Oct 8, 2018 1:37 PM UTC
Please note that if you select "Scale3-Low", you will be able to enter the value of the frequency in "User Choice" field. In this case, you need to select first "User-defined" as CPU Frequency.
-Amel
ATirl
ATirlAuthor
Oct 9, 2018 7:14 AM UTC
Hello Amel,
Thanks for your time ! In the case i select "Scale3-Low", CPU freq is selectable but i still cannot specify Clock Source frequency. It is fixed to 4 MHz. Doesn't Clock Source frequency affect power consumption ? I plan to use 20 MHz crystal by the way.
Nawres GHARBI
Oct 25, 2018 9:08 AM UTC
The PCC clock is independent form your project configuration.
We are working on synchronizing this tool and it will be available in a next release with all clock configurations
