Dec 24, 2018 3:28 PM UTC
CubeMX more GPIO View and FATFS
- 2 replies
- 1089 views
Dear ST support,
1. The following attached the issue of some pins being overwritten by the last pin configuration, I also didn't find the hide feature in the configuration pop-up.
how i can solve this issue ?
2. what is the correct configuration for 1-bit sdcard mode on BSP FATFS (Platform proposal)?
because when I was ignored then I got a warning like in figure 2
Thank you in advance
