Divesh Dutt
CubeMx in Linux machine
Hi guys i want to install cubeMx in my linux machine and i search it on google then it pop up results and shows some steps but it is showing me in .exe format and is not installing.Any Suggestions?
Hello @Divesh Dutt​ ,
Please refer to the UM1718 user manual and follow the steps/requirements for installing and running STM32CubeMX under Linux.
https://www.st.com/content/ccc/resource/technical/document/user_manual/10/c5/1a/43/3a/70/43/7d/DM00104712.pdf/files/DM00104712.pdf/jcr:content/translations/en.DM00104712.pdf
Make sure that you have administrators rights and you have installed Java Run Time Environment for 1.7.0_45 or later.
With Regards,
Imen.
