cubeMX gets stuck when using freertos and cubeIDE
When I use STM32cubeMX, add the FreeRTOS and select STM32cubeIDE as the IDE, click to generate code, cubeMX will get stuck at Copying libraries files. What should I do, thanks for the help.
    STTwo-32
    Hello @Rxt_Master and welcome to the ST Community :smiling_face_with_smiling_eyes:.
    I've succeeded to generate the code based on the .ioc file that you added to this post. I suggest you use the last versions of CubeMX and CubeIDE. Also, it will better if you restart your PC.
    Best Regards.
    STTwo-32
    Thank you for your answer, but my cubeMX is already the latest version, and I have also tried restarting, but it does not work
    Pavel A.
    November 12, 2023
    @Rxt_Master Is your school IT available to help? Do they install any "security" software on your computers, besides of the Windows "defender"? If so, try to disable it temporarily?
    I've tried turning off the firewall and anti-virus software, but it still doesn't work
    Johi
    Senior II
    November 12, 2023
    I had a similar problem today.
    - Be patient, after some time it came through.
    - Be sure you are logged on.
    - Be aware of message boxes asking for confirmation related to licenses.
