frackers
Senior
Feb 25, 2020 8:51 AM UTC
CubeMX generates garbage CDEF line in Makefile
I've just recently started to use makefiles and one of the requirements is passing a few defines to the compiler.
These I define in CDEF as
CDEF = -DVAR1 -DVAR2 -DVAR3
but after running the code generation, CubeMX has changed that to
-DCDEF = VAR1 VAR2 VAR3
which does absolutely nothing as the variable DCDEF is not referenced in the gcc command line
What is it trying to do?
Cheers
Houssem CHAABANI
Nov 18, 2020 8:17 AM UTC
Dear @frackers​,
Thank you for your feedback.
It's recommended to use the last version of STM32CubeMX.
Could you please share you .IOC file ?
Best regards,
Houssem
