Senior III
Jan 25, 2019 8:12 PM UTC
CubeMX-generated project with FreeRTOS and Lwip fails to compile!
- 7 replies
- 982 views
I generated a simple project to create a base for a project including a web server on STM32F429 Nucleo board.
The CubeMX-generated code fails to build.
This morning, within CubeMX plug-in I downloaded and installed the latest pack and CubeMX, but the Help->About still says version 5.0.0 STMCube v1.0. What version am I actually running?
I've attached the IOC so you can easily generate code and reproduce the problem.
Please let me know how to get a working example!
Thanks, Best Regards, Dave
