Srdjan Nikolic
CubeMX - FATFS on SD-card for V2 Interface.
In CubeMX
there is not possible to select SD-Card support in FATFS if CMSIS V2 interface is selected for FreeRTOS.
It worksonly for CMSIS V1.
Are there any plans to support FATFS on SD-card for V2 Interface?
Nesrine.JLASSI
February 20, 2020
Hello @Community member​
Thanks for the feedback,
It will be available next CubeMX version.(weak 9)
Fatfs SD card mode will be enabled with CMSIS RTOS v2.
Best regards,
Nesrine
Srdjan Nikolic
Thanks for the info.
B.R.
Srdjan
