Mikk Leini
Senior
CubeMX does not remember free pins generation context
STM32CubeMX v6.16.1 has a small bug. Under Project Manager - Code Generator - HAL settings is an option to pick under which context the free pins should be set as a analog. I am using STM32N6 which has 3 contexts (FSBL, App, ExtMemLoader).
The problem is that CubeMX doesn't store (or recall) this setting. I want to set them under Appli, but on every program start it sets the context to FSBL. After doing same "fix" for tens of times it gets quite annoying.
Souhaib MAZHOUDBest answer
Hello @Mikk Leini
Thanks for bringing this issue to our attention!
This issue has been raised internally to the dedicated team for further investigation. (Ticket 225346 This is an internal tracking number and is not accessible or usable by customers.)
KR, Souhaib
To give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question.
Hello @Mikk Leini
KR, Souhaib
Mikk Leini
Senior
Hello ​@Souhaib MAZHOUD. It is still an issue in CubeMX v6.18.1. Every single time project change is made, additional manual fix (set pins context back to Appli) is required. I have done it hundreds of times and it gets really frustrating to figure out that there are unwanted changes and then you have to re-generate.
