Tobe
Senior III
CubeMX does not export ADC functions
When i export the pins from Cube, it does so, except for the ADC pins.
Its CubeIMX 6.8.0
Ghofrane GSOURI
Hello @Tobe
First let me thank you for posting.
1- Could you please  explain what do you mean by "export ".
2- Could you please try to use the latest version of CubeMX 6.10.0
It will be helpful if you tell  the exact scenario in order to reproduce your issue
Thx
Ghofrane
Tobe
TobeAuthor
Senior III
1: I "explain" with a picture. In the datasheet it is called "Additional functions"
2: No i will not test your new version.
Ghofrane GSOURI
Hello again @Tobe
Thank you for your contributions and for your detailed explanations,
I confirm the issue on my side, it has been reported to STM32CubeMX development team .
Internal ticket number: 167358(This is an internal tracking number and is not accessible or usable by customers).
Thx
Ghofrane
AScha.3
just --- this "export pins" : what is it useful for ? and where import then ?
Ghofrane GSOURI
Hello @AScha.3
Export pinout with Alternate functions :Generates pin configuration as a .csv text file including alternate
functions information, this file can be (later) imported into a board layout tool.
Thx
Ghofrane
AScha.3
Thx    , @Ghofrane GSOURI .
