PureBasic
May 31, 2019 10:49 PM UTC
CubeMX do clean project folders of unused HAL and LL driver files, but doesn't for Middleware.
Generating code for "Other Toolchain" with a Middleware Enabled in MX generates the code as expected.
Then, if you disable the Middleware in MX and generate again, the files that were generated previously are not Deleted from the Inc and Src folder.
In my case, some #include directives are not removed neither.
