Graduate
CubeMX code generation switches project from C++ to C causing build and linker errors
My projects are all in C++ and were building completely fine. After I generated the code from CubeMX, the language switched back to C. I had to go and manually switch to C++, then it gave me build errors with linker script... Please fix!
Souhaib MAZHOUDBest answer
Hello @spaceDog16
Actually, this issue has been solved in the latest version of CubeMX 6.16.1, I suggest that you update your version of CubeMX and recheck.
BR, Souhaib
To give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question.
Hello @spaceDog16
BR, Souhaib
