Lukasz Przenioslo
CubeMX changes optimization flags again
  • August 13, 2018
  • 8 replies
  • 3285 views
CubeMX and libs version as in this topic: https://community.st.com/s/question/0D50X00009cegytSAA/l4-cubemx-package-ver-112-inconsistency?t=1534139773066
The problem is that each time one regenerates the project using CubeMX, the optimization flags get reset to -Os, no matter what was set before:
Debug level flags are preserved correctly. @Imen DAHMEN​  ?
Mohamed Mansouri
August 14, 2018
Hi @Community member​ ,
Unfortunately, I'm not able to reproduce this issue.
Could you please provide more information about your environment (windows version, atollic version..) . It will be more helpful if you share your Ioc and if you tell us about the scenario to reproduce the issue.
Thanks in advance for helping to complete this thread.
Regards,
Mohamed
kurta999
Senior
September 6, 2018
I can comfirn this bug. It even resets optimization flags in my new configuration what I made.0690X000006BzQaQAK.png
Lukasz Przenioslo
@Mohamed Mansouri​ So do you need any input from me or is the @kurta999​  post OK?
Mohamed Mansouri
September 7, 2018
Can you please give your Atollic TrueSTUDIO version and the MCU used.
Because using STM32F401, I cannot reproduce the bug. I change the optimization level to -0g and when i regenerate the code, it was kept, it wasn't changed to -Os,
Thanks in advance for helping to complete this thread,
Regards,
Mohamed
Lukasz Przenioslo
The MCU is STM32L452VE, Truestudio version is 9.0.1
Mohamed Mansouri
September 7, 2018
Can you please share your Ioc
Lukasz Przenioslo
Here it is.
Mohamed Mansouri
September 7, 2018
Thank you,
I confirm: With your Ioc, I succeed to reproduce the Bug. Its not the case with an empty project,
I will get back to you as soon as I get the right reason for this bug,
Thanks for your helping,
Regards,
Mohamed
