dieter 123
Feb 8, 2017 12:09 PM UTC
CUBEMX and TIM1 channel 1 PWM generation
Posted on February 08, 2017 at 13:09
Hi
in CUBEMX for a L476XX I would like to set up a PWM channel. In the pinout tab of cube under TIM1 I can choose between 'PWM generation ch1' and  'PWM generation ch1N'.
So is it like it just switches the pin for channel 1?
What does ch1N stand for?
In which document would I find the description?
THX
#cubemx-4.19 #timer
Feb 8, 2017 12:42 PM UTC
Posted on February 08, 2017 at 13:42
Hello
dieter.dieter
You should refer to the reference manual
http://www.st.com/content/ccc/resource/technical/document/reference_manual/02/35/09/0c/4f/f7/40/03/DM000835pdf/files/DM000835pdf/jcr:content/translations/en.DM000835pdf
related to your device STM32L476xx (inAdvanced-control timers (TIM1/TIM8) section )and this
http://www.st.com/content/ccc/resource/technical/document/datasheet/c5/ed/2f/60/aa/79/42/0b/DM001088pdf/files/DM001088pdf/jcr:content/translations/en.DM001088pdf
toreview the pins description and identify the free/usable pins assignment in your configuration.
Imen
