bully
Senior
May 1, 2019 8:55 AM UTC
CubeMX and LwIP : DHCP packet is sent, but something is wrong
I'm trying to get DHCP working as an initial step in using LwIP. Have generated project with CubeMX and now I'm catching the problem.
Using Wireshark, I can see that DHCP Discover packet is sent, but no response is received. IT seems that something is wrong with the packet. As a reference, I also captured DHCP packet from my laptop that does work and gets response.
Any advice what is wrong ?
Thanks in advance,
regards,
Rob.
Packet from STM32F439 :
No. Time Source Destination Protocol Length Info
 3006 49.570106 0.0.0.0 255.255.255.255 DHCP 350 DHCP Discover - Transaction ID 0x5851f42d
Frame 3006: 350 bytes on wire (2800 bits), 350 bytes captured (2800 bits) on interface 0
 Interface id: 0 (\Device\NPF_{A7ACDF3A-ED3E-4FAD-B7B4-533C6D411BF2})
 Encapsulation type: Ethernet (1)
 Arrival Time: May 1, 2019 10:37:34.873435000 Srednjeevropski poletni �?as
 [Time shift for this packet: 0.000000000 seconds]
 Epoch Time: 1556699854.873435000 seconds
 [Time delta from previous captured frame: 0.075670000 seconds]
 [Time delta from previous displayed frame: 11.888756000 seconds]
 [Time since reference or first frame: 49.570106000 seconds]
 Frame Number: 3006
 Frame Length: 350 bytes (2800 bits)
 Capture Length: 350 bytes (2800 bits)
 [Frame is marked: True]
 [Frame is ignored: False]
 [Protocols in frame: eth:ethertype:ip:udp:dhcp]
 [Coloring Rule Name: UDP]
 [Coloring Rule String: udp]
Ethernet II, Src: Stmicroe_00:00:00 (00:80:e1:00:00:00), Dst: Broadcast (ff:ff:ff:ff:ff:ff)
 Destination: Broadcast (ff:ff:ff:ff:ff:ff)
 Source: Stmicroe_00:00:00 (00:80:e1:00:00:00)
 Type: IPv4 (0x0800)
Internet Protocol Version 4, Src: 0.0.0.0, Dst: 255.255.255.255
 0100 .... = Version: 4
 .... 0101 = Header Length: 20 bytes (5)
 Differentiated Services Field: 0x00 (DSCP: CS0, ECN: Not-ECT)
 Total Length: 336
 Identification: 0x0001 (1)
 Flags: 0x0000
 Time to live: 255
 Protocol: UDP (17)
 Header checksum: 0xba9c [validation disabled]
 [Header checksum status: Unverified]
 Source: 0.0.0.0
 Destination: 255.255.255.255
User Datagram Protocol, Src Port: 68, Dst Port: 67
 Source Port: 68
 Destination Port: 67
 Length: 316
 Checksum: 0xf773 [unverified]
 [Checksum Status: Unverified]
 [Stream index: 8]
 [Timestamps]
Dynamic Host Configuration Protocol (Discover)
 Message type: Boot Request (1)
 Hardware type: Ethernet (0x01)
 Hardware address length: 6
 Hops: 0
 Transaction ID: 0x5851f42d
 Seconds elapsed: 0
 Bootp flags: 0x0000 (Unicast)
 Client IP address: 0.0.0.0
 Your (client) IP address: 0.0.0.0
 Next server IP address: 0.0.0.0
 Relay agent IP address: 0.0.0.0
 Client MAC address: Stmicroe_00:00:00 (00:80:e1:00:00:00)
 Client hardware address padding: 00000000000000000000
 Server host name not given
 Boot file name not given
 Magic cookie: DHCP
 Option: (53) DHCP Message Type (Discover)
 Length: 1
 DHCP: Discover (1)
 Option: (57) Maximum DHCP Message Size
 Length: 2
 Maximum DHCP Message Size: 1500
 Option: (55) Parameter Request List
 Length: 3
 Parameter Request List Item: (1) Subnet Mask
 Parameter Request List Item: (3) Router
 Parameter Request List Item: (28) Broadcast Address
 Option: (255) End
 Option End: 255
 Padding: 000000000000000000000000000000000000000000000000…
and working DHCP packet from laptop (and DHCP offer it gets as a response) :
 280 37.678948 0.0.0.0 255.255.255.255 DHCP 351 DHCP Discover - Transaction ID 0xac96b414
Frame 280: 351 bytes on wire (2808 bits), 351 bytes captured (2808 bits) on interface 0
 Arrival Time: May 1, 2019 10:37:22.982277000 Srednjeevropski poletni �?as
 Epoch Time: 1556699842.982277000 seconds
 [Time delta from previous captured frame: 0.235728000 seconds]
 [Time delta from previous displayed frame: 0.000000000 seconds]
 [Time since reference or first frame: 37.678948000 seconds]
 Frame Number: 280
 Frame Length: 351 bytes (2808 bits)
 Capture Length: 351 bytes (2808 bits)
Ethernet II, Src: Pegatron_bb:30:10 (0c:54:a5:bb:30:10), Dst: Broadcast (ff:ff:ff:ff:ff:ff)
 Source: Pegatron_bb:30:10 (0c:54:a5:bb:30:10)
 Type: IPv4 (0x0800)
 Total Length: 337
 Identification: 0x62af (25263)
 Flags: 0x0000
 Time to live: 128
 Protocol: UDP (17)
 Header checksum: 0x0000 [validation disabled]
 Source: 0.0.0.0
 Source Port: 68
 Length: 317
 Checksum: 0xa8e9 [unverified]
 [Stream index: 8]
 [Timestamps]
 Hops: 0
 Transaction ID: 0xac96b414
 Seconds elapsed: 0
 Client MAC address: Pegatron_bb:30:10 (0c:54:a5:bb:30:10)
 Magic cookie: DHCP
 Length: 1
 DHCP: Discover (1)
 Option: (61) Client identifier
 Length: 7
 Option: (50) Requested IP Address (192.168.0.212)
 Length: 4
 Requested IP Address: 192.168.0.212
 Option: (12) Host Name
 Length: 22
 Host Name: Robi_Ideapad710_laptop
 Option: (60) Vendor class identifier
 Length: 8
 Vendor class identifier: MSFT 5.0
 Length: 14
 Parameter Request List Item: (6) Domain Name Server
 Parameter Request List Item: (15) Domain Name
 Parameter Request List Item: (31) Perform Router Discover
 Parameter Request List Item: (33) Static Route
 Parameter Request List Item: (43) Vendor-Specific Information
 Parameter Request List Item: (44) NetBIOS over TCP/IP Name Server
 Parameter Request List Item: (46) NetBIOS over TCP/IP Node Type
 Parameter Request List Item: (47) NetBIOS over TCP/IP Scope
 Parameter Request List Item: (119) Domain Search
 Parameter Request List Item: (121) Classless Static Route
 Parameter Request List Item: (249) Private/Classless Static Route (Microsoft)
 Parameter Request List Item: (252) Private/Proxy autodiscovery
 Option: (255) End
 Option End: 255
bully
bullyBest answer
Senior
May 1, 2019 9:04 AM UTC
Stupid mistake.
forgot to include MX_LwIP_Process in while loop...
Regards,
Rob.
bully
bullyAuthorBest answer
Senior
Stupid mistake.
Regards,
Rob.
