Shen
Apr 2, 2022 3:37 PM UTC
CubeMX 6.5.0 code generation error when ADC enables temperature sensor�?Vref and Vbat channel(LL library)
Hello Everyone,
I am using STM32G474RE and the STM32CubeMX version is 6.5.0.
When ADC5 enables temperature sensor�?Vref and Vbat channel, STM32CubeMX will generate code in MX_ADC5_Init function(LL library):
/** Configure Regular Channel
LL_ADC_REG_SetSequencerRanks(ADC5, LL_ADC_REG_RANK_1, LL_ADC_CHANNEL_VREFINT);
LL_ADC_SetChannelSamplingTime(ADC5, LL_ADC_CHANNEL_VREFINT, LL_ADC_SAMPLINGTIME_2CYCLES_5);
LL_ADC_SetChannelSingleDiff(ADC5, LL_ADC_CHANNEL_VREFINT, LL_ADC_SINGLE_ENDED);
LL_ADC_SetCommonPathInternalCh(__LL_ADC_COMMON_INSTANCE(ADC5), LL_ADC_PATH_INTERNAL_VREFINT);
LL_ADC_REG_SetSequencerRanks(ADC5, LL_ADC_REG_RANK_2, LL_ADC_CHANNEL_TEMPSENSOR_ADC5);
LL_ADC_SetChannelSamplingTime(ADC5, LL_ADC_CHANNEL_TEMPSENSOR_ADC5, LL_ADC_SAMPLINGTIME_2CYCLES_5);
LL_ADC_SetChannelSingleDiff(ADC5, LL_ADC_CHANNEL_TEMPSENSOR_ADC5, LL_ADC_SINGLE_ENDED);
LL_ADC_REG_SetSequencerRanks(ADC5, LL_ADC_REG_RANK_3, LL_ADC_CHANNEL_VBAT);
LL_ADC_SetChannelSamplingTime(ADC5, LL_ADC_CHANNEL_VBAT, LL_ADC_SAMPLINGTIME_2CYCLES_5);
LL_ADC_SetChannelSingleDiff(ADC5, LL_ADC_CHANNEL_VBAT, LL_ADC_SINGLE_ENDED);
LL_ADC_SetCommonPathInternalCh(__LL_ADC_COMMON_INSTANCE(ADC5), LL_ADC_PATH_INTERNAL_VBAT);
I think there is a line of code missing after line 12:
LL_ADC_SetCommonPathInternalCh(__LL_ADC_COMMON_INSTANCE(ADC5), LL_ADC_PATH_INTERNAL_TEMPSENSOR);
Besides, calling LL_ADC_SetCommonPathInternalCh() function will clear the previous state, so I think it should be modified to this code:
LL_ADC_SetCommonPathInternalCh(__LL_ADC_COMMON_INSTANCE(ADC5), LL_ADC_PATH_INTERNAL_VBAT|LL_ADC_PATH_INTERNAL_VREFINT|LL_ADC_PATH_ INTERNAL_TEMPSENSOR);
​Best regards,
Shen
Walid ZRELLI
Walid ZRELLIBest answer
Apr 7, 2022 11:18 AM UTC
Hello @Shen​
Thank you for your contribution.
This issue has been reported internally.
Internal ticket number: 126032 (PS: This is an internal tracking number and is not accessible or usable by customers)
BeST Regards,
Walid
Walid ZRELLI
Apr 4, 2022 11:05 AM UTC
Hello Shen,
In order to allow a better analysis of your problem, could you please give us the .ioc file that you are used to reproduce this issue.
BeST Regards,
Walid
Shen
ShenAuthor
Apr 5, 2022 2:27 PM UTC
Hello Walid,
Thank you for your reply, here is my .ioc file.
Walid ZRELLI
Hello @Shen​
BeST Regards,
Walid
