Sara BEN HADJ YAHYABest answer
Apr 20, 2022 8:00 AM UTC
Hello @lafa ,
I apologize for the late reply and thank you for having reported.
You are right, the HRTIM init in LL code is corrupted, it seems that this issue occurs only when the "General peripheral initialization as a pair of .c/.h files per peripheral " parameter is checked. By unchecking it, the HRTIM init code generation will be correct in main.c.
I submitted an internal ticket to fix this issue, I will keep you posted.
Internal ticket number: 126646 (This is an internal tracking number and is not accessible or usable by customers).
If your issue is solved, please close this post by clicking the "Select as Best" button. This will help other members of the community find this response more quickly :)
Sara.
