JJason57Associate7 months agoApr 2, 2026 04:35 UTCSolvedCubeMX 6.16 generated code: HAL_GetTick() always returns 02 replies288 viewsHi,I use cubemx to generate code for STM32CubeIDE, compile is OK, but the initial process run fail with HAL_Delay function, the HAL_GetTick() always return 0 so the program blocked here. attached is my .ioc file, any anyone help for thie issue?EnergeCube_V01.iocSTM32CubeMXSysTick
