CubeMX 6.16.0's "Memory Management" Tool assumes 1 kB granular sections for linker file generation
CubeMX 6.16.0 "Memory Management" used for ethernet and with enabled linker file generation creates the following [ORIGIN adapted from default]:
RxDescripSection (rwx) : ORIGIN = 0x30040000, LENGTH = 0K
TxDescripSection (rwx) : ORIGIN = 0x30040060, LENGTH = 0K
Rx_PoolSection (rwx) : ORIGIN = 0x30040200, LENGTH = 1K
What I would have expected was:
RxDescripSection (rwx) : ORIGIN = 0x30040000, LENGTH = 96
TxDescripSection (rwx) : ORIGIN = 0x30040060, LENGTH = 96
Rx_PoolSection (rwx) : ORIGIN = 0x30040200, LENGTH = 1536
[with just 1 ETH RX buffer - see this other post ].
Can someone explain to me whether this is intentional - maybe because of a constriction with the MPU granularity?
Or whether CubeMX handles this wrong and should allow sub-kilo-byte granularity?
Best regards
Johannes
Ghofrane GSOURI
Ghofrane GSOURIBest answer
Hello ​@JohannesWilde
This issue has been fixed in the latest version of STM32CubeMX 6.18.0
Download STM32CubeMX6.18.0 from  here
THX
Ghofrane
Ghofrane GSOURI
Hello @JohannesWilde
Could you please provide your IOC?
THX
Ghofrane
See here .
Ghofrane GSOURI
Thank you very much for your valuable contribution.
Ticket 224785 has been escalated to the development team to correct this behavior.
I will keep you informed of any updates.
Thanks,
Ghofrane
Ghofrane GSOURI
THX
Ghofrane
