CubeMX 6.15 does not regenerate code
Hi all,
I recently updated the IDE to v1.19 and MX to v6.15.0, and the MX code generation is no longer working for me.
After some testing, I found out I can create new projects and code is (apparently) well generated. After this first generation, if i change anything in CubeMX and regenerate, the .ioc file is updated accordingly but the code is not changing at all.
My device is STM32U575VG (FW package 1.8.0).
As an example I created a project with just TIM1, generated the code, added TIM2 through CubeMX and renegerated.
I attach the first .ioc file (DELME_New_Project.ioc) and the updated (DELME_Updated_Project.ioc) for reference. The code has not been updated:
Any ideas? Am I missing something? Is anyone else facing this problem?
Alex
ACCBest answer
Hi @Ghofrane GSOURI,
I had already tried deleting the .stm32cubemx folder before posting, and a few other things I read on other similar posts.
Using a local workspace solved the problem for me. I have had the workspace on a server directory for years without issues until now.
Thank you anyway.
Ghofrane GSOURI
Hello @ACC
Could you please provide more details about your OS.
I have tested your IOC file, "DELME_Updated_Project.ioc," and, as shown in the screenshot, the generated code is correct.
Afterward, I configured additional peripherals (ADC1 and DAC), regenerated the code, and confirmed that everything is working as expected.
So I suggest that you close the CubeMX and then delete  the following folder .stm32cubemx  (On Windows: C:\Users\<YourUsername>\.stm32cubemx)
Then  Restart CubeMX and try again generate the code using your IOC  and make sure to use a new workspace
THX
Ghofrane
ACCAuthor
Hello @Ghofrane GSOURI,
I'm using Windows 11.
Ghofrane GSOURI
Hello @ACC
I performed the test using Windows 11 and MX is working correctly , which suggests that the issue may be specific to your environment. Please follow the steps outlined in my initial comment, and let me know your results. I will be awaiting your feedback.
THX
Ghofrane
ACCAuthorBest answer
Thank you anyway.
