George.P
May 7, 2015 10:54 AM UTC
CubeMX 4.7.1 - STM32L1 1.2.0
Posted on May 07, 2015 at 12:54
Has anyone tried to use the temperature sensor on STM32L1 devices with the latest CubeMX and library?
It's giving me bogus results (-2C on my desk), while on older versions it worked normally.
Chip is STM32L151RCT6 and the compiler IAR 7.40.
The project is a test project containing only CubeMX generated code for the GPIO and ADC and the temperature calculations from AN3964.
Tried Vref channel on a separate project and it measures the correct VCC (3V3).
Thanks!
George
#cubemx #temperature #stm32l1
Amel NASRI
May 18, 2015 1:51 PM UTC
Posted on May 18, 2015 at 15:51
Hi George,
Could you please tell me what is the ''older version'' for which project was working as expected?
-Mayla-
