farukisiker
CUBEIDE Bug in RTC Generation
In CubeIDE I try to generate RTC code which has decimal parameters. However in code generation I realized that it converted to hex value by itself.
You can check screen shots in the attachment.
Hello @farukisiker
Thank you for posting!
Could you mention the name of the MCU where you encountered the issue?
KR,
Souhaib
To give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question.
farukisiker
Stm32H7 Series
This behavior is correct. 12 decimal expressed in BCD format is 0x12. If you change it to binary format, it will be 12.
farukisiker
You can check that video to ensure that there is a problem here.
BCD only shows that the number is between 0-9. It even does not accept hex value during configuration.
