tekampe
Aug 11, 2016 6:17 AM UTC
Cube MX and Flash
Posted on August 11, 2016 at 08:17
Hey,
i'm using CubeMX to generate code. In one of the examples is an EEPROM emulation (STM32Cube_FW_F1_V1.4.0\Projects\STM32F103RB-Nucleo\Applications\EEPROM\EEPROM_Emulation) which I want to use.
My Problem is that I can not find the Button in CubeMX so that the generated stm32f1xx_hal_conf.h enables the HAL_FLASH_MODULE_ENABLED define.
I hope you can help me.
Jens
#cubemx-hal-flash
Nesrine M_O
Aug 11, 2016 9:30 AM UTC
Posted on August 11, 2016 at 11:30
Hi Jens,
The flash is enabled by default using CUMEMX.
-Syrine-
