matt-crc
Senior III
Oct 26, 2025 4:50 AM UTC
CUBE-IDE / CubeMX Bug? Cannot setup clock for STM32N6 processor
Does anyone know how to setup the clock source for the N657 processor?  I want to use an oscillator for the HS clock input and setup HSE = Bypass clock source...
using Bypass clock it should only use PH0 (clock in) and free up the PH1 pin (clock out).  But it seems the IDE / cubeMx always wants to use both pins regardless of the clock configuration.
am I missing something or is this a bug?
thanks, Matt
Ghofrane GSOURI
Ghofrane GSOURIBest answer
Feb 25, 2026 11:26 AM UTC
Hello @matt-crc @AScha.3
This issue has been resolved in the latest version of STM32CubeMX 6.17.0
Link to download
THX
Ghofrane
AScha.3
Oct 26, 2025 9:01 AM UTC
maybe small inaccuracy in Cube ,or N6 just dont switch off osz-out . (read in rm or errata...what it should do)
But it has enough other pins, so not  free up the PH1 pin is nothing to worry about.
matt-crc
matt-crcAuthor
Senior III
Oct 27, 2025 6:36 PM UTC
@AScha.3
The reason I was asking about PH1 is because I need that pin, which means there isn't enough pins... lol
AScha.3
Oct 27, 2025 7:56 PM UTC
@matt-crc
Which cpu we talking about ?  264 pins ? and need every pin ??
matt-crc
matt-crcAuthor
Senior III
Oct 27, 2025 8:21 PM UTC
yes
AScha.3
Oct 27, 2025 9:38 PM UTC
Show your circuit... :)
matt-crc
matt-crcAuthor
Senior III
Oct 28, 2025 12:04 PM UTC
Hello @Ghofrane GSOURI
Can you also address this post, this appears to be another bug with the Cube-MX software, where the clock pins are not allocated properly.  You can use the same .ioc file as the previous ticket.
Let me know if you need additional info.
thanks
Matthew
Ghofrane GSOURI
Oct 29, 2025 7:36 AM UTC
Hello @matt-crc
I appreciate your helpful contributions.
According to RM0486 Rev 2, Section 14.6.2: External clock source (HSE bypass):PH1 (OSC_OUT) is not required for HSE bypass mode.
Ticket 220815 has been escalated to the development team for further investigation and resolution of this behavior.
THX
Ghofrane
Ghofrane GSOURI
Link to download
THX
Ghofrane
