NniblettrVisitor IIApr 22, 2026 12:31 PM UTCQuestionCube generate code for MDK-ARM clobbers User->After Build/Rebuild->Run #2 field in uvision0 replies164 viewsSee attachment, field gets erased every time I re-generate code using STM32 CubeMX.problem seen on versionsSTM32CubeMX version 6.16.1uVuion/Keil version 5.43This has been ongoing for a while so problem does exist on older versions of both.STM32CubeMXBug-report
