CPU caches checkboxes blocked
I have enabled generation of linker script (need to redefine memory layout).
There is no possibility to change  state of checkboxes of both CPU caches if this generation has been enabled.
The state of the checkboxes may be on or off, but grayed out.
You have to:
- disable linker script generator
- enable chaches
- reenable linker script gen
Setup of the cache strictly follows the state of the checkboxes.
