hamrgh
Sep 19, 2016 2:50 PM UTC
Connect 2 board to each other with Ethernet Protocol
Posted on September 19, 2016 at 16:50
hi
I working with stmf429 board with cubemx and HAL driver and i must run ethernet protocol (with LWIP or without)
I want to connect 2 boards to each other
(for example press key and led light up in other board)
 I do not know where to start
Anyone who knows please help me .
thanks
#stm32f4 #cubemx #ethernet
slimen
Sep 19, 2016 3:32 PM UTC
Posted on September 19, 2016 at 17:32
You'll probably want to review Ethernet examples as you can find available in the
http://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32cube-embedded-software/stm32cubef4.html
package:
STM32Cube_FW_F4_V1.13.0\Projects\STM324x9I_EVAL\Applications\LwIP
You can refer to this
http://www.st.com/content/ccc/resource/technical/document/reference_manual/3d/6d/5a/66/b4/99/40/d4/DM00031020.pdf/files/DM00031020.pdf/jcr:content/translations/en.DM00031020.pdf
it provides complete information on how to use the STM32F4xx microcontroller memory and peripherals.
Have a look to these documents:
http://www.st.com/content/ccc/resource/technical/document/user_manual/79/6e/5f/d4/5c/25/43/96/DM00103145.pdf/files/DM00103145.pdf/jcr:content/translations/en.DM00103145.pdf
, it maybe helpful as it provides a full description of how to implement In-Application Programming (IAP) using Ethernet communication.
http://www.st.com/content/ccc/resource/technical/document/application_note/fd/5d/64/cf/7c/38/4c/30/DM00036052.pdf/files/DM00036052.pdf/jcr:content/translations/en.DM00036052.pdf
''LwIP TCP/IP stack demonstration for STM32F4x7 microcontrollersâ€�  .
http://www.st.com/content/ccc/resource/technical/document/user_manual/65/e8/20/db/16/36/45/f7/DM00103685.pdf/files/DM00103685.pdf/jcr:content/translations/en.DM00103685.pdf
is a user manual about “Developing applications on STM32Cube with LwIP TCP/IP stack� which can help you a lot to go further in your application.
hamrgh
hamrghAuthor
Sep 20, 2016 8:51 AM UTC
Posted on September 20, 2016 at 10:51
thank you for your answer!
Things that you mentioned include too much subjects for me
I do not have much time for drive ETH
I just want to connect 2 board for run led & key connection.
If you know which of the available program can do it directly ، Notify me
thanks again
