SBébi.1
Code generation problem on HAL_PWREx_S3WU_IRQHandler
I'm working on an STM32U595 and there is a code generation problem in the function `void PWR_S3WU_IRQHandler(void)` where when you have multiple wake up pins and S3WU interrupt enabled :
/* USER CODE END PWR_S3WU_IRQn 0 */
HAL_PWREx_S3WU_IRQHandler(PWR_WAKEUP_PIN2 || PWR_WAKEUP_PIN5 || PWR_WAKEUP_PIN6);
/* USER CODE BEGIN PWR_S3WU_IRQn 1 */
But the generated code should be:
HAL_PWREx_S3WU_IRQHandler(PWR_WAKEUP_PIN2 | PWR_WAKEUP_PIN5 | PWR_WAKEUP_PIN6);
This creates a big problem because as soon as you define several wake up pins in stop mode 3, it no longer works.
Best regards,
Steven
STTwo-32
STTwo-32Best answer
Salut @SBébi.1
Thank you so much for your escalation. I've reported this to our concerned team for correction  (under internal ticket number 207504).
PS: this has been solved on the version 6.15.0 of the STM32CubeMX.
Best Regards.
STTwo-32
STTwo-32
STTwo-32Best answer
Salut @SBébi.1
Best Regards.
STTwo-32
