May 9, 2022 11:40 AM UTC
Code generation fails on ArchLinux with OpenJDK 18.0.1.1
- 2 replies
- 1901 views
My code generation fails with the following exception :
Exception in thread "Thread-4645" java.lang.IllegalAccessError: class parsers.FromScratchParser (in unnamed module @0x6a84a97d) cannot access class com.sun.org.apache.xerces.internal.parsers.DOMParser (in module java.xml) because module java.xml does not export com.sun.org.apache.xerces.internal.parsers to unnamed module @0x6a84a97d
at parsers.FromScratchParser.getDestinations(FromScratchParser.java:257)
at convertor.Convertor.generate(Convertor.java:354)
at com.st.microxplorer.plugins.projectmanager.model.ToolchainGenerator.generate(ToolchainGenerator.java:370)
at com.st.microxplorer.plugins.projectmanager.engine.ProjectBuilder.createToolChainFolders(ProjectBuilder.java:4150)
at com.st.microxplorer.plugins.projectmanager.engine.ProjectBuilder.createProject(ProjectBuilder.java:916)
at com.st.microxplorer.plugins.projectmanager.engine.GenerateProjectThread.run(GenerateProjectThread.java:54)Here's my java version
�?� java --version
openjdk 18.0.1.1 2022-04-22
OpenJDK Runtime Environment (build 18.0.1.1+2)
OpenJDK 64-Bit Server VM (build 18.0.1.1+2, mixed mode)Full log is attached.
