Changes to SVCall_IRQn Preemption Priority trigger assert
CubeMX allows the user to change the Preemtion Priority of the “System service call via SWI instruction” / SVCall_IRQn.
When its not at the default value of 0, CubeMX generates this HAL_NVIC_SetPriority(SVCall_IRQn, X, X); inside HAL_MspInit(). When USE_FULL_ASSERT is enabled this function call triggers an assert. Namely assert_param(IS_NVIC_PRIO_INTERRUPT(IRQn)) where IRQn is SVCall_IRQn and IS_NVIC_PRIO_INTERRUPT(X) checks if IRQn is != to SVCall_IRQn.
I noticed this on a STMU385, using CubeMX version 6.18.1
Best Regards, Cecil
Ghofrane GSOURI
Ghofrane GSOURIBest answer
Hello ​@CecilW
This issue has been fixed in the latest version of STM32CubeMX 6.19.0
THX
Ghofrane
Ghofrane GSOURI
Hello ​@CecilW
Could you please share your IOC in order to reproduce this behavior.
THX
Ghofrane
CecilWAuthor
Hi Ghofrane
Thank you for the fast reply.
I created a minimal .ioc and it also shows the same behaviour. To reproduce simply change the SVCall_IRQn prio to something other than 0 and it will generate the function containing the failing assert.
Best Regards, Cecil
Ghofrane GSOURI
Hello ​@CecilW
Your valuable contribution is much appreciated.
A ticket  #0065391 has been escalated to dev team for further investigation.
I will keep you posted with updates.
THX
Ghofrane
Ghofrane GSOURI
Hello ​@CecilW
THX
Ghofrane
